66 300 HP auto optional exhaust - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2163
    Can anyone tell me for certain whether or not N11 off road exhaust was an available option on a 66 300 HP auto?
    • 43279
    Re: 66 300 HP auto optional exhaust
    Russ------
    GM says that N-11 was only available with manual transmission.
      • 15706
      All C2 250 HP and 300 HP/PG had 2" exhaust pipes. N11 was 2.5", so it would only couple to the front pipes of the other engine/transmission combinations that had 2.5" head pipes.
      I don't think you can install 2.5" systems on PG due to interference with the transmission.
        • 43279
        Duke-----
        For 1966 all Corvette small blocks used 2" outlet exhaust manifolds regardless of horsepower or transmission. However, for one reason or another GM chose to not make the N-11 system available with Powerglide. As far as I know, this applied to both big blocks and small blocks.
        • Russ S.
          • April 30, 1982
          • 2163
          Thanks guys. Very interesting that as Joe states even the big block with auto didn't come with the n11 option but side exhaust was available.
            • 15706
            Duke-----
            Yes, but the head pipes for 300HP/MT and 350 HP were 2.5" with 2" adapters welded on to fit the 2" manifolds. N11 was the 2.5" rear section pipe/muffler assembly, only. The front section for N11 was the same as base exhaust and is 2.5" at the center joint between the front and rear sections.
            • Russ S.
              • April 30, 1982
              • 2163
              Duke, So are you thinking that N11 was available with 300 auto?
              • Jeff S.
                • July 31, 1984
                • 384
                Russ
                The GM engineering/spec package literature for '66 model year reads as follows (page 14, options & accessories section):
                EXHAUST SYSTEM - OFF ROAD SERVICE. Available with any optional engine with 4 speed transmission ........... N11
                BTW, I attempted to install a service replacement/counter purchased N11 system on a '66 base engine p/glide car back in ancient times. There was interference on the passenger side between the header pipe and the transmission pan area. It can be solved by having a custom bent pipe made, it seems. If I recall correctly, the welded tailpipe/muffler assembly was double wall pipe -- I'm not sure about the header pipe.
                • Russ S.
                  • April 30, 1982
                  • 2163
                  Jeff, Thank you. That sheds additional light on the subject. I appreciate all your responses. That's not what I wanted to hear but is what I suspected.I like it correct, but who wants to put a puny 2 inch exhaust on their car even if it is an auto?
                    • 15706
                    No, 300 HP/PG used 2" pipes from the exhaust manifold to the center joint,and the rear section is also 2". The N11 rear section is 2.5" and is designed to connect to a 2.5" front section, so that's why it was limited to 300HP/MT and 350HP for small blocks, both of which used 2.5" front sections with welded on 2" adapters to connect to the 2" manifolds beginning in '66.
                    From '62 to '65 all 300HP/MT and all higher power SB engines used 2.5" manifolds and 2.5" head pipes all the way from the manifold connection to the center connection.
                      Originally posted by Jeff Smith (7732)
                      Russ
                      Jeff -
                      That implies that N11 wasn't available with the base (300hp) engine in '66, although the '66 JG just says it was limited to manual transmissions only without mentioning any engines.
                      The Chevrolet information in the '67 Engineering/spec package only says with manual transmissions, which implies that it was available with the base (300hp) engine in 1967.
                      N11 isn't addressed in the exhaust section of the AMA Submission, as it's an option.
                      Does anyone have any other Chevrolet-published information that can shed more light on the availability of N11 in '66 and '67 with small-block engines?
                        • 43279
                        Jeff -
                        John-----
                        The 1966 Chevrolet Order Guide says regarding RPO N-11:
                        "Off-Road Service----available only when 3 or 4 speed manual transmission is ordered"
                          John-----
                          Joe -
                          Thanks - that would imply that N-11 was available with both the 300hp and 350hp engines, in 1966 and 1967, only with manual transmissions.
                          I have the '67 order guide, but don't have the '66 order guide.
