wheel question for 67 - NCRS Discussion Boards
  • Michael F.
    • 745
    will a 67 vette rim fit on a 93 chevy truck...the bolt pattern that is, is it the same???? I want to put the rims/tires on my truck while I work on the vette.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Paul J.
    • September 9, 2008
    • 2091
    Re: wheel question for 67
    The bolt pattern is the same, all GM's are 4-3/4". Ford and Chrysler are 4-1/2".
    I'm assuming that you are talking about non-stock rims, but if you're not, stock 67 Vette rims may be narrower, and the offset is different. Also the stock truck tires were larger than those on a stock 67 Vette.
    • David L.
      • July 31, 1980
      • 3310
      According to my 1996 Hollander the 93-94 Chevy 2WD trucks that uses 15 X6 wheels (GM # 9591157, Hollander # 1613) are 5 stud, 5" bolt circle. The 67 Corvette rims are 4 3/4" bolt circle.
      The 93 Chevy 2WD S10 wheels have a 4 3/4" bolt circle but the offset is different. The 67 Corvette wheels will still work on any S10 but the distance between the left wheel and the right wheel will be closer by about 0.31" or so. The 67 Corvette 15 X 6 wheel has an offset of +0.06". I believe the 2WD S10 wheels have an offset of -0.25" as best as I cam remember.
        • 15595
        Paul, My 1995 Caprices have a wheel bolt pattern of 5 x 5. I think Chevrolets use either 4-3/4 or 5-inch patterns, or the metric equivalent; but which goes with what Chevrolet vehicle is rather complicated. I just don't know what other GM divisions have done for wheels.
        • Ridge K.
          • May 31, 2006
          • 1018
          My '67 Corvette has it's original wheels removed for restorative work, and I have a set of late model Chevrolet S-10 slotted steel wheels mounted on it so it can roll around the shop.
          I can't address the late model full size truck wheels .
          Ridge
          • Robert G.
            • May 31, 1990
            • 429
            I doubt the hub size is correct. I couldn't get my vette rims to fit on a 1988 Olds Cutlass though the bolt pattern was good.
            • Michael F.
              • 745
              thanks for replys, won't be able to use 67 wheels temp on truck I guess, no biggie. onward with the vette restoration and new tires for truck.
              Michael
