Holley Carb - NCRS Discussion Boards
Holley Carb
  • David T.
    • August 31, 1995
    • 51
    Holley Carb
    I met a fellow who claims to have a new in the box Holley Carb for a 1966 427 390 HP Vette. Can anyone verify the part number and give me an idea of what it's worth? Thanks.
    Dave
    Dave T.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Holley Carb
    I show 3882835 EO List # 3370 I also show a 3892341 with K19 List # 3606
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Pancho T.
      • July 31, 1993
      • 238
      Re: Holley Carb
      Dave
      original or service date on the carb? Huge difference in price
      • Timothy B.
        • April 30, 1983
        • 5201
        Re: Holley Carb
        Check to see if Holley is still making these carbs and check archives for some info. I had a service replacement 3810 on my 67 for years with no complaints, nothing wrong with service replacement carburetors.
        • Pancho T.
          • July 31, 1993
          • 238
          Re: Holley Carb
          A service dated carb should work fine but like I said large difference in value between original and service dated
          • David T.
            • August 31, 1995
            • 51
            Re: Holley Carb
            Where would I look for the service date on the carb?
            Dave T.
            • Pancho T.
              • July 31, 1993
              • 238
              Re: Holley Carb
              the date is just under the list#
              • Timothy B.
                • April 30, 1983
                • 5201
                Re: Holley Carb
                Pancho,
                That's true but other then the date the carburetor is the same.
                • David T.
                  • August 31, 1995
                  • 51
                  Re: Holley Carb
                  The list number is 3606 and beneath it it looks like 5B2. Does this mean something like a service date of Feb. 5, 1972?
                  Dave T.
                  • Pancho T.
                    • July 31, 1993
                    • 238
                    Re: Holley Carb
                    Originally posted by Timothy Barbieri (6542)
                    Pancho,
                    in operation yes and for the most part in appearance not quite.For one there was a change in the base of the carbs a number of years ago.Somewhere around I have some pictures of a couple of the differences.
                    • Pancho T.
                      • July 31, 1993
                      • 238
                      Re: Holley Carb
                      3606 is correct for a 390hp car with K19 (smog)
                      5B2= 2nd week of Dec. 1965 so a good date
                      • Robert G.
                        • May 31, 1990
                        • 429
                        Re: Holley Carb
                        Depending on the age, the gaskets may not be suitable for gas with ethanol so a rebuild before using may be necessary.
