65 Dash Harness - NCRS Discussion Boards
65 Dash Harness
  • Brenton M.
    • May 31, 2006
    • 66
    65 Dash Harness
    I purchased all new wiring harnesses for my 65 big block roadster, My ouestion is, Near the fuse block there is two red wires with ring terminals on them can some one tell me if these wires are for a circuit breaker.
    If so what type in where is it mounted.
    My other question are, on the tail light wiring harness there is one plug that I'm not sure where it goes, its a round plug i think it had two wires on it, the others were tail light, rear compartment light plug, tag light. I'm not sure about the large round plug.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 Dash Harness
    Yes, headlight motor circuit breaker -- the clip that holds this breaker is located below the upper of two vertical oval holes in the steel birdcage, and the breaker upper edge is about 1" below the bottom of the top oval hole.
    Sounds like the plug that goes into the power antenna motor. A round plastic male plug with a release tab on the side.
    • Jonathan S.
      • February 20, 2009
      • 65
      Re: 65 Dash Harness
      Wayne as usual is right on the money!
      • Brenton M.
        • May 31, 2006
        • 66
        Re: 65 Dash Harness
        Thanks guys, sound like you all are right on the money.
