Replace drivers side dash pad on "64 - NCRS Discussion Boards
  • Gerard S.
    • December 21, 2009
    • 5
    I would like to replace the drivers side dash pad on my 1964 Corvette. I am searching for the best replacement part and guidance on the removal and installation. Appreciate any help you can provide.
    Thanks!
  • Joe R.
    • January 13, 2010
    • 51
    Re: Replace drivers side dash pad on "64
    Gerard, I just went through this although I had my glovebox and cluster out at the same time so that made it a lot easier for access. Not sure how tight it will be with them installed. The process is fairly easy once you know how the clips work. The attached thread does a great job of explaining how to work the clips. The only other item holding them in are 2 nuts.
    https://www.forums.ncrs.org/showthre...moval&uid=2736
    As far as replacements, from what I have read the 2 viable options are Corvette America and Al Knoch. Seems to be a camp in favor of each but neither will be an exact match to the original and your passenger side. If you are only going to replace one, I would hunt for a good used original.
    Joe
