Has anyone developed a method of dealing with the bumps that occur on 68-72 C3's due to corrosion of the aluminum rivets on the headlamp support bar that does not risk damage to the front surround panel. It seems to me that it would be possible to cut off the peened end of the rivets and remove the steel bar leaving the bonding strip attached to the surround. Next, a spot weld cutter (a very small hole saw with spring loaded pilot) could used to make a 1/2" hole in the bonding strip beneath each rivet to remove the corroded rivet from beneath without cutting the into the surround panel. The steel bar would then be bonded to original bonding strip using whatever kind of adhesive that was used on later C3's to attach the headlamp support bar without the use of the corrosive rivets. The integrity and paint of the surround panel would not be affected, and I am hoping that bumps may settle down at least partially over time on a car with only a few mild bumps. Certainly it would prevent any further growth of bumps.
Has anyone already tried this idea?
What was the adhesive used on 73-81 C3's without rivets.
Does anyone know where I could get a piece of a wrecked surround with the headlamp bar in place to practice this idea?
