C! headlight bezel differences - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1060
    I have a few different C1 headlight bezels here that were included with the parts I received with the 60 I aquired a few months back. One is part number 3742509 and the other is 3779239. What is the difference?
    One thing I did note is that the area that curves back to meet the fender trim is shorter on the 3742509. I have three of the 3779239 and each one measures different to the fender trim.
    Tom
    2007 Z06, Lemans Blue
  • Joe M.
    • April 30, 1990
    • 1338
    Re: C! headlight bezel differences
    The 1960 Assembly Instruction Manual only shows one part number, 3742509. Don't know why, but the part is called a "door"!
    • Thomas H.
      • August 31, 2005
      • 1060
      Joe,
      I did see that the AIM called out the 3742509. Maybe the other part number is a service replacement? Although the car I have is a one owner car with no records of changing the headlight "doors" and it had the 3779239 parts on it.
      You can definitly see a construction difference between the two parts. I wonder if they changed part numbers mid stream in early 1960 as the car I have was built in May 1960.
      Tom
      • Roger W.
        • January 29, 2008
        • 567
        The 3779239 is for a 61-62 Corvette per my old GM Corvette parts book. This should be painted the same color as the car. The 3742509 is for a 58-60 corvette and is chrome.
