Generator alignment - NCRS Discussion Boards
Generator alignment
  • David H.
    • November 11, 2009
    • 777
    Generator alignment
    OK, I've searched and read everything in the archives and I still don't understand why my generator pulley seems to be as much as 2" behind the alignment of the water pump and crankshaft pulleys.
    From what I gather tho, the '62 340 hp engine had a "special" generator bracket that was different from all the others. I had to purchase a replacement generator mount from Paragon because my brother's car had an alternator on it with a different mount bracket.
    What am I missing that would move the generator forward about 2 inches?
    • 6948
    Re: Generator alignment
    Dave do you have a AIM to show you the mounting of generator, I am not a C 1 guy, but could there be a spacer on the lower bracket that would move the generator to the inside of the lower bracket and the spacer would be on the front of the lower bracket?
      I see your generator U-bracket, but I can't see your support... The picture looks like you took a 'big hammer' approach to bolt the U-bracket directly onto the exhaust manifold.
      Check out the Paragon catalog for their #522, 1962 generator mounting plate. You should also find the 'support' called out in your copy of the AIM as mounting between the U-bracket and the exhaust manifold. This is what translates the generator forward...
      • David H.
        • November 11, 2009
        • 777
        OK, so I must need the #522 plate that attaches to the manifold, then the u bracket attaches to the plate. I wish Paragon had told me that when I talked to them about the u bracket.
        Thanks, and fyi, no hammers were used in the restoration of this car.
        (I'm not sure what you are seeing in the picture but the u bracket bolted right up to the manifold, no problem.)
        • Timothy B.
          • April 30, 1983
          • 5188
          David,
          You may also want to check the water pump hub distance from the block. The W/P belt pulley looks farther away from the W/P casting boss.
          I think the measurements are in the archives..
            Cut the order takers at Paragon some slack. They can't see what you have/don't have when you book an order and most aren't restoration experts.
            What I saw in the picture was the exhaust mani and the generator U-bracket. There was NO black plate extending below the U-bracket which is the mounting plate or support that's called out in the AIM.
            This isn't an uncommon restoration mistake (mounting the U-bracket directly to the exhaust mani) since you have to look at the AIM closely to see there's an extra part 'sandwiched' between the U-bracket and the exhaust manifold. It's visible things like this that trigger the older judges as they walk around looking at this/that--the picture of what they see doesn't 'jive' with what they remember a given item should look like.
            Sometimes it takes a while for the 'grey room' upstairs to spit out what's 'wrong' with the picture I'm seeing here/today... But, it usually pops out given a moment or two of reflection.
            • David H.
              • November 11, 2009
              • 777
              OK, thanks all. I can see it now in the AIM. It's on its way.
              • Robert K.
                • July 31, 1984
                • 213
                Is the u bracket correct? Paragon calls for all non-FI use the bracket with 3 holes in it. I seem to recall mine has 3 holes, but I haven't looked at it in 30 years.
                • David H.
                  • November 11, 2009
                  • 777
                  The '62 340hp does take the three hole "U" bracket but also needs the 4 hole support bracket that bolts to the manifold first. Adding the water pump pulley reinforcement washer brought everything into alignment perfectly!
                  Thanks for the help!
