66 Hubcap part help - NCRS Discussion Boards
66 Hubcap part help
  • Joe R.
    • January 13, 2010
    • 51
    66 Hubcap part help
    I am in the process of restoring my 66 hubcaps and have a part that only showed up on 1 out of my 4 hubcaps. Per the attached picture, one of my hubcaps has an extra thim metal solid disc that was riveted on behind the plastic flag emblem (upper right). All of the original rivets look intact on the other hubcaps so not sure if they fell off at some point or if they were ever there. I searched all of the corvette houses and none show this as a replacement part. So I have a couple questions. 1) was this "cap" installed on all hubcap spinners? 2) If yes, does anyone know a source to find them? 3) If no source, would there be a judging hit if I reassembled without them? Thanks - Joe
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 66 Hubcap part help
    Joe, can you see it with the hub cap assembled?
    • Joe R.
      • January 13, 2010
      • 51
      Yes, there is a hole on the backside of the hubcap a little smaller than a quarter. Dark in there but if you looked in you could see.
      • Rob M.
        • April 30, 2003
        • 657
        Joe,
        Mine look much as yours do. I just cleaned them up as best I could with some fine steel wool and re-used them. I checked LIC and didn't see them listed separately and assume they might sell it as part of the spinner. Anyway, you might call them and ask if they sell it separately (or try calling Paragon).
        Good luck
        Rob
        '66 327/300 Regional Top Flt
        '08 6 speed coupe
        • Ryan V.
          • May 31, 2006
          • 23
          Joe,
          I have set of 4 original hubcaps, and all four of mine have that 'cap'.
          - Ryan
          • Joe R.
            • January 13, 2010
            • 51
            Thanks Ryan, upon closer inspection it looks like the 3 with the missing cap had the center emblems replaced at some point. It looks like they have been re-peened over. Probably wasnt enough meat on the rivet to install the new emblem and cover. Anyway, now off to search for an obscure set of hubcap inner caps....
            • Michael J.
              • January 27, 2009
              • 7145
              When my '66 was judged they did not remove the hubcap, so if it is on the back, it will not be judged.
