Found some in a bag...1967 Bolt & Hardware ID? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11335
    I got a box of stuff from the owner of the '67 which he saved since 1968. My kinda' guy. Like 14 feet of nos original teal blue seatbelt webbing....and a bunch of original appearing hardware. There' are about 100 pieces altogether, but these below in the photos are most interesting.
    I think the 1/4-20 with the toothed washer is for the throttle lever ground strap, and the 4 "FP" 3/8-16's are for the front bumper lower bracket, but the others I'm unsure about.
    Rich
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11335
    Re: Found some in a bag...1967 Bolt & Hardware ID?
    ...more stuff.
    • Rich P.
      • January 12, 2009
      • 1361
      Richard,
      picture #1
      toothed washer bolt is small block fuel pump plat to block,
      flying f is for later modle ignition/ spark plug shielding (mid 70's up because of the flat washer and not split ring lock washer
      CH bolt is 70-up accesorry brackets many locations
      1/4-20 j bolt is the same configuration as rear body valance upper bolts but an incorrect headmark must be from some other GM car. I have seen these on Oldsmobies and GTO's
      Rich
      • Rich P.
        • January 12, 2009
        • 1361
        post #1
        picture #2
        these have been used on rear seat mount for 63-66's and occasionally I have seen them on underdash brackets. They are the longer 1" style and would only have been used on the under dash brackest by mistake and They were supposed to be 3/4" long with a pinched tip. This is also used on some 68-up cars for the front outer bumper bracket to small header supports as well as the headlight actuator housings (the front 4 bolts)
        • Rich P.
          • January 12, 2009
          • 1361
          Post #1
          PICTURE #3
          The front lower bumpers to bracket bolts are 7/16-14 thread not 3/8-16. Grade 2 FP bolts like these I have pulled off of 50's and 60's era cars
          • Rich P.
            • January 12, 2009
            • 1361
            post #1
            picture #4
            if this a 3/8" hex it is a upper grill rod to header bolts. if it is 1/4" hex head then it's too long for a heater blower motor bolt, if its a 5/16" hex then it would be a courtesy light bracket bolt or lower heater Y duct to heater box bolt
            • Rich P.
              • January 12, 2009
              • 1361
              Post #2
              picture #1
              to the left of the picture mostly interior hardware, I see Door sill screws, door pull screws, conv latch to header screws, 1 kick panel screw, the 2 cups with the (most likely L headmaked) 10-24 bolts with 5/16" hex heads are for the top outer corner windshield trim, I see hard to trim and dash hardware. Lots of good stuff. If there is any you specifcally ned identefied post individual pics.
              • Rich P.
                • January 12, 2009
                • 1361
                Post #2
                pic #3
                looks like ecklers bought GM hardtop hardware, 2 ferrels and 2 side retainers
                • Rich P.
                  • January 12, 2009
                  • 1361
                  Post #1
                  picture #1
                  addition to first reply since this was a convertablt the bolt with the double circles and star washer could also have been used for the convertable lid latch. The 2 release cables were held in with 4 bolts and clamps This is the same style bolt used there
                  • Kevin G.
                    • February 1, 2005
                    • 1076
                    Richard,
                    See my recent post! Your first picture has the one I have been searching for!
                    https://www.forums.ncrs.org/showthre...83958&uid=5286
                    • Rich P.
                      • January 12, 2009
                      • 1361
                      Richard,
                      Kevin,
                      close your trans bracket bolt is 3/8-16 not 5/16-18. Almost but not quite.
                      Rich
                      • Kevin G.
                        • February 1, 2005
                        • 1076
                        Originally posted by Rich Pasqualone (49858)
                        Kevin,
                        Rich
                        Drat! Thanks Rich!
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11335
                          Rich.......all I can say is WOW! That was a awesome response. Thanks very much!
                          Kevin, yes Rich is right. I replaced those the other day when we put in the transmission and the holes are for 3/8".
                          Rich
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11335
                            Post #2
                            pic #3
                            Yes...the date on the Ecklers labels are 1988! I had another friend who had lots of GM bags with Ecklers labels at around the same time.
                            Rich
