Help ID ing bolts, C2 - NCRS Discussion Boards
  • John R.
    • November 1, 2005
    • 433
    Going through a box of bolts for a project I have. Can anyone help to ID these bolts? Thanks in advance for your help.
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Help ID ing bolts, C2
    Look like half shaft bolts at flange.
    1964 Red FI Coupe, DUNTOV '09
    • Rich P.
      • January 12, 2009
      • 1361
      At first glance they look like the 1/2 shaft bolts but then I looked a second time and noticed that the heads LOOK to be 1/2 the normal thickness and a bit bigger then the normal 5/8" hex so I vote for pressure plate. Cant tell for sure unless you show a profile of one to see the width of the head. If they are pressure plat bolts the hex head will fit an 11/16" socket.
      Rich
      • John R.
        • November 1, 2005
        • 433
        Put a 11/16th wrench on them. So I guess they are pressure plate bolts. Thanks.
