71 ls6 454 holley info needed - NCRS Discussion Boards
  • Jeff M.
    • February 1, 1999
    • 127
    71 ls6 4spd was holley #4802A for the 4 speed, GM#3986195 and I belive came with 72/76 jets, what were the power valve specs?? The 3310-1 says it came with 10.5 primary and 8.5 secondary. Does holley have these specs anywhere??
    I am sure JOE wil know
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 71 ls6 454 holley info needed
    the holley parts book says both were #85
    • Jeff M.
      • February 1, 1999
      • 127
      Just found it in my holly book at it shows 8.5 in both, but jetting of 70/76, i hope Joe can confirm
      • Clem Z.
        • January 1, 2006
        • 9427
        i bet the carb had a molded filler in the metering body area next to the float bowl to reduce the fuel volume for emission readings. most all OE holley carbs had this in the 70/71 time frame. those carbs were set up to meet emissions not performance. those carbs were jetted lean with a richer power valve restriction to get them thru emission tsting. i had a new 70 454 450 HP chevelle that was set up like this.
          • 43219
          Jeff----
          The jets are 70 and 76.
          By the way, the application used a Holley 4803A and not a 4802A.
          • Clem Z.
            • January 1, 2006
            • 9427
            Jeff----
            the 4803 (6808 A) uses a different pri metering body than the 4802(6671 A)
