69 Rochester carb idle - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    When I first start up my 350/350, I push the acccelerator down once to activate the choke and it starts however the idle speed is about 2500 and then when it warms up and I kick it down it idles just where it should, around 700 and will continue at that speed all day at idle. My question is this, the 2500 just seems awfully fast for the intial startup with the choke on, should it be this fast?
    • 15640
    Re: 69 Rochester carb idle
    My memory of the 1970 350/350 (L46) is that is about what the book says. I would suggest you look up the fast idle specification in your copy of the 1969 Factory Service Manual to confirm my recollection.
    That said, given we usually don't start our Corvettes in sub-zero temperatures you can reduce the high speed idle easily if you wish. The instructions, complete with photographs for those of us who respond better to visual stimulus, are in the same 1969 Factory Service Manual.
    • Clem Z.
      • January 1, 2006
      • 9427
      choke on idle speed can be set on all carbs. check your corvette shop manual
      • Lawrence M.
        • February 1, 1995
        • 404
        You are very close. The Ops Manual & PV Test Guide calls for 2400 on the 69 L46. It is very easy to turn the fast idle down for summer driving and back up for judging.
        Larry
        2002 Z51 Convertible
        1969 L46 Convertible
        • Clem Z.
          • January 1, 2006
          • 9427
          those RPMs listed in the GM manuals are for a engine already up to temp not cold start.
          • Timothy B.
            • April 30, 1983
            • 5202
            If the book setting is like my 63 and 67 engines, as Clem states it's with a warmed engine. There will be quite a difference in engine speed when it's cold (slower).
            Also, this is usually set on the first or second step of the cam which sets when the choke is completely closed. After start up and after the choke pull off opens the choke valve usually you can touch the throttle and the step will lower and slow the idle.
