Interior cover assembly (straps) (C1) - NCRS Discussion Boards
  • Ron R.
    • August 31, 1993
    • 159
    I'm trying to attach the Interior cover assembly (straps) to the underside of the deck of my 61. These ae the straps that go over the outer edges of the seats. Part numbers 3729017LH and 3729018RH. They don't line up with the screws that hold the deck SS. There may be a screw/washer in the assembly manual but I'm not clear on how to correctly attach. I have the deck down with hard top on presently. She is a hard top only 61.
    Ron
  • John F.
    • March 23, 2008
    • 2415
    Re: Interior cover assembly (straps) (C1)
    See pictures of my original early 1962 straps. #0029. Hope this helps.
    • Bruce B.
      • May 31, 1996
      • 2930
      The clips that hold on the decklid trim are not used for the covers.
      Each has 2 short screws that go into the decklid.
      • Ron R.
        • August 31, 1993
        • 159
        Thank you John. A picture is worth a thousand words. The screw heads were a little blurry but I'm assuming Phillips head. I'll get em installed this weekend.
        Ron
