How long to allow a car to sit? - NCRS Discussion Boards
+ More Options
Posts
    • 15706
    #31
    Re: How long to allow a car to sit?
    If you want the battery to last for more than a few years, you should charge it before you attempt to start the car.
    The engine may start with a significantly discharged battery, but it won't last long. Batteries have a sort of "chemical memory". If you commonly crank the engine with a significantly discharged battery, pretty soon it will never get back to full charge at all and fail early.
    I have a friend with several cars, but he's not very mechanically astute. He typically only drives them once a month and he was complaining that his high price "premium" batteries only lasted a couple of years.
    Once I convinced him to either charge the battery before starting if the car sat more than a week or leaving a battery tender on them, his short battery life "problem" went away.
    A typical service type battery - the kind you have to add water to - losses about three percent per day at room temperature. Discharge rate is faster at higher temperature and lower at lower temperature.
    A sealed battery has somewhat different chemistry and their discharge rate is only about one percent per day at room temperature, so a maintenance free battery is definitely the way to go.
    I have two $39.95 Autozone (made by Johnson Controls) batteries that are closing in on ten years old and still going strong because I charge them before using the cars if they've sat a week or more, and I don't use battery tenders.
    • Ronald L.
      • October 18, 2009
      • 3248
      #32
      Sitting at ride height - I don't agree to let a car sit on the tires, they get flat and bias ply will never be the same.
      To get the car off the ground you put the stand under it so the tires are just free clear, that way the suspension is happy and the tires too.
      If you have a car sit a year, and more, and I do, the tires are so square they never are really the same any more. Been doing this, two years no use, starts up and runs great and no shimmy or vibration due to tire deformation.
