62 side cove louvered molding blackout - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    The Judging manual indicates that the side cove area where the louvered molding on a 62 goes is blacked out. Can someone please post a picture showing this blackout (preferably showing the blackout without the molding in place, but any pic will be helpful)?
    Also is it a semi-flat black finish?
    Tony
  • Mike M.
    • May 31, 1974
    • 8401
    Re: 62 side cove louvered molding blackout
    none of the fiberglass is blacked out, just the cove moulding itself, sparing the horizontal ribs that show the moulding's chrome plating. mike
    • Anthony P.
      • June 27, 2010
      • 485
      Ahhh..... Thanks for clarifying that.
      Tony
      • Mike E.
        • February 28, 1975
        • 5141
        Actually, the front face of the cove area is blacked out. That's the area that would be parallel with the front of the car. (Probably the best way to describe it is the area that on a 58-61 has an insert that the spears leading edge fastens through. It was semi-gloss black. When you look at a car that is body color in that area, it's obvious that the car has had a repaint and attention wasn't paid to detail.
        • John F.
          • March 23, 2008
          • 2415
          The front face on the inside of mine is black. #0029
          • Terry B.
            • December 6, 2010
            • 73
            If we are discussing the area I think we are then my 62 is body color and I believe that I have original paint. Are we talking about the area that forms a "cave" into which the chrome insert fits?
            • Mike E.
              • February 28, 1975
              • 5141
              If that area that the leading edge of the louvers buts up to is not blacked out, you do not have original paint.
              • Terry B.
                • December 6, 2010
                • 73
                I've had two C1 knowledgeable NCRS members inspect the car and specifically asked one about the paint neither stated that the paint was not original. The previous owner certainly believed it was original paint. Also when I read the judging information description of original paint it all seems to match. This is the car that Dale Pearman wrote about in the fall of 1994 where he mentioned your name in regards to RPO 684 (metallic brakes but not heavy duty shocks), do you have any knowledge of that car that Dale may have passed alone that I might like to know about? I'm at work right now so I don't have access to all my records.
                • John M.
                  • May 31, 1990
                  • 198
                  Anthony: Perhaps the 3 attached photos might better clairfy what Mike McCagh and Mike Ernst have described. The photos show the correct paint detail for the 62 side cove.
                  • Terry B.
                    • December 6, 2010
                    • 73
                    That is the area I'm talking about. I wonder how they got black out in there but no body paint. At any rate if my paint isn't original then my car is no longer a BowTie candidate and I can restore it without a guilty conscience.
                    • John F.
                      • March 23, 2008
                      • 2415
                      Mine is exactly like John M's pictures.
                      • Anthony P.
                        • June 27, 2010
                        • 485
                        JohnM, Thanks for those pictures. That is exactly what I was trying to understand.
                        Do you know if there is any blackout on the inside edge of that small lip (the small lip that goes just over the front edge of the grille molding where it slides in)? You probably would not be able to see in there without a small mirror.
                        Tony
                        • Mike E.
                          • February 28, 1975
                          • 5141
                          Not intentionally, but don't forget, this was assembly-line production, and they just quickly blew a little paint in there and moved on.
                          • Mike E.
                            • February 28, 1975
                            • 5141
                            Don't toss the baby out with the bathwater. It's always possible a previous owner did something there, and a small bit of paint work does not disqualify the car. Make sure before you restore. There are restored 62's everywhere--there are only 6 or 7 62 bowtie cars.
                            Mike
                            • John F.
                              • March 23, 2008
                              • 2415
                              Just took a mirror to mine and it looks like a little overspray of the body color on the rough fiberglass.
