Wax removal - NCRS Discussion Boards
Wax removal
  • John K.
    • December 2, 2010
    • 24
    Wax removal
    Buying a 65 coupe from original owner. Car has an enormous amount of wax build-up or never removed wax everywhere. Whats the best way to remove. Car has original paint.
    • 6942
    Re: Wax removal
    John, dawn dishwashing liquid will remove automotive wax. and a little elbow grease. squeez some on a soft towel and a clean bucket of water and dawn also.
    • Larry M.
      • January 1, 1992
      • 2695
      Re: Wax removal
      John:
      Ed's advice may be the best/safest.
      However PPG Acryliclean DX 330 Wax and Grease Remover is another alternative. Used by me and by professional body shops for removing wax and grease on painted automotive surfaces prior to re-painting. This stuff is very mild, and will leave a non-wax (dull) finish. You will need to then go back and add your polish or wax of choice.
      But the DX 330 may be more than you want/need. Consider it if the Dawn doesn't do what you want. And if you do use the DX 330, try it on some lower front or rear panels first. Just in case.
      Larry
      • Keith L.
        • April 7, 2008
        • 378
        Re: Wax removal
        Use warm water with the Dawn. Use warm to rinse if you can. Wash it a couple times that way.
        • Frank E.
          • May 31, 1986
          • 189
          Re: Wax removal
          You might try a clay bar. It will remove wax and any surface contaniments that the finish may have....
          Frank
          1966 Milano Maroon Roadster
          2004 CE Z06
          • Bruce S.
            • January 1, 2006
            • 26
            Re: Wax removal
            Just use Dawn dish washing liquid with warm water as a car wash. It has a high alkaline content which cuts thru carnauba wax, paraffin, and silicone oils. Rinse your car with warm water. I would do this a couple of times, and then dry off with a chamois towel. This should get your paint finish clean, and free of any wax. Follow up with a good clay bar treatment on your paint finish.
            Bruce
            • John K.
              • December 2, 2010
              • 24
              Re: Wax removal
              Thanks for all the advice..will try the dawn and warm water first.
              • Jack C.
                • September 30, 1992
                • 1090
                Re: Wax removal
                John, please post some before and after pix when you get a chance.
                Jack Corso
                1972 Elkhart Green LT-1 Coupe 43,200 miles
                Top Flight 1994, 2018 & 2021
