80w-90 Gl-5 - NCRS Discussion Boards
80w-90 Gl-5
  • Kenneth F.
    • September 30, 1988
    • 282
    80w-90 Gl-5
    Is this choice of gear oil acceptable for a B/W T-10? If not what should be used?
    Ken
  • Jim D.
    • 2884
    Re: 80w-90 Gl-5
    That will be just fine. Go a head and use it.
      • 15679
      Re: 80w-90 Gl-5
      The original spec was Mil-L-2105. This spec was cancelled about the decade ago and the military now uses the API equivalent spec which is SAE 80W-90 GL-5, so that's what you should use.
      Brand doesn't matter. Like engine oil, buy gear oil by API spec.
      • Eric D.
        • February 1, 1992
        • 42
        Re: 80w-90 Gl-5
        You need GL-4 gear lube, the GL-5 has the friction modifier for use with POSI rear ends,
        which is the same additive that makes the sycro rings not work...
        Hope this helps... Eric
        • Dick W.
          • 10483
          Re: 80w-90 Gl-5
          GL-5 will work fine with synchronized transmissions
          Dick Whittington
            • 15679
            Re: 80w-90 Gl-5
            No, 80W-90 GL-5 DOES NOT have the Positraction additive, It is the modern equivalent of Mil-L-2105 that GM specified for all these old manual transmissions when they were manufactured in the sixties and seventies. Mil-L-2105/80W-90 GL-5 is also the correct lubricant for open hypoid axles.
            Positraction axles require the addition of a "friction modifier" additive to common 80W-90 GL-5 to avoid clutch chatter (stick-slip friction), and it is the same additive that is included in all ATFs since all automatics have wet clutches.
            I have seen some commercial 80W-90 GL-5 packages that state "suitable for limited slip differentials", but that doesn't mean it has the additive.
            The only axle oil I know of that has the Positraction additive included in the product is Redline 75W-90. They also offer the base oil without the Positraction additive that is called 75W-90NS.
            • Kenneth F.
              • 282
              Re: 80w-90 Gl-5
              Thanks to everyone for this interesting much appreciated information.
              Ken
