I had previously painted the exhaust manifolds with a well known high heat silvery paint. Now I have removed the manifolds and wish to remove all traces of this paint prior to re installing them on the car. Someone had suggested bead blasting them. Has anyone had experience with removing the paint.? Now for the second question. The studs that hold the exhaust pipes are threaded into the manifolds with a coarse thread and I've been advised that the portion of the studs protruding from the manifolds are of a fine thread and uses a special nut to hold the exhaust pipe to the manifold. My present studs have coarse threads at either end. This post only seems to bring more questions. The manifolds when removed from the block previously had gaskets and now I want to re install without the gaskets. Is there anything special required to ensure the surfaces mate properly prior to reassembly.
Thank You
Ralph Harvey
Thank You
Ralph Harvey
