radiator replacement hose - NCRS Discussion Boards
  • Robert P.
    • December 15, 2010
    • 12
    hello all: i need some help in locating a radiator air bleed hose for my 93 lt1. it is listed in the GM service manual on page 6b-12 figure 9 item #7. any help would be appreciated. bob p 52552.
  • John G.
    • January 1, 2006
    • 85
    Re: radiator replacement hose
    If your looking for the pipe between the heads, Keen parts supplied mine and I betcha they can hook you up with the hose to the tank. Tom is a member and advertises in the Driveline
    John G
      • 43291
      Robert------
      If you mean the radiator surge tank and air bleed hose, it was only available as a complete assembly which included tube and hose sections. It was GM #10135654 but it was discontinued about 5 years ago and as far as I know is not reproduced.
      • Robert P.
        • December 15, 2010
        • 12
        hi joe: yes,that is the one i mean. i already did a search and came up with the same info. last reproduced 5 years ago but discontinued. i was hoping perhaps someone would have knowledge of one around somewhere. the leak is at the front of the pipe from the radiator where the rubber hose changes into the aluminium pipe through a compressed fitting. i can have it repaired through a local radiator shop,but he will have to alter the makeup of the pipe,and i was trying to keep it original. thanks for the input it is much appreciated. bob p 52552.
        • Robert P.
          • December 15, 2010
          • 12
          John G
          thanks john: i will connect with keen parts right away. thanks for the input. bob p 52552
          • Robert P.
            • December 15, 2010
            • 12
            John G
            hi john: keen was able to locate a radiator surge tank hose for me. thanks for help. bob p 52552
