Setting up convertible top frame - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    Does anyone have a proceedure for setting up a convertible top frame? Do the door windows and all weatherstrips need to be installed first?
    Re: Setting up convertible top frame
    Mike -
    The header and basic frame must be set up first (rags in photos below simulate installed/compressed weatherstrips), then install the weatherstrips and adjust the door glass to match. When that's all done, then you can move on to the pads and the skin. Once the skin is on, it's too late to adjust the header. Photos are of a '58, but the sequence is the same.
    • Mike R.
      • August 30, 2009
      • 321
      Thanks John. I am trying to decide whether to paint or try to set the top. I think I will paint first.
      • Randy R.
        • March 1, 1983
        • 477
        If you have a two top car, set the windows to fit the hardtop first.
        • Anthony P.
          • June 27, 2010
          • 485
          Question on the assembly line for 61 and 62's (maybe other years as well).
          For some reason I thought that the complete convertible top assembly including the skin was together, and then installed as a complete unit?
          Is that correct? If so, that must have lead to other alignment challenges in alignment and how was it accomplished.
          Tony
          • Donald H.
            • November 2, 2009
            • 2589
            Mike -
            John,
            I have a 1960 restoration in progress and am a long way from setting up the top, but I do have a question. Randy's comment below suggest setting the window adjustment to the hardtop first. If I do that, is the convertible frame adjustable enough to then fit the window? Your instruction is to do the basic soft top frame set up first then adjust the window to that.
            Don
            Don Harris
            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
              Originally posted by Donald Harris (51003)
              John,
              Don
              Don -
              That's correct - if you have a hardtop, set the window glass to the hardtop first, then install the top frame and adjust it to fit the glass - there's adequate adjustment to do that; that's how the plant did it.
              C1 soft tops arrived at St. Louis as a completed assembly, ready to install on the car; they were built by the supplier on a buck that duplicated the Corvette body.
              C2 soft tops arrived as an assembly, less the front header and weatherstrips, which were installed at St. Louis.
