Shifter Lubrication? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I have a rebuilt 4 speed shifter for my 1966 car. When it was done it was disassembled, the levers on the bottom were parkerized, and it was reassembled using new clips, good pins, etc. It is nice and tight. What type of lubrication should I use, if any? One suggestion I got was a lithium spray.
    Thanks.
  • Stephen B.
    • August 31, 1992
    • 261
    Re: Shifter Lubrication?
    Larry
    Don't know whats the very best lub for this application ,but I've use white lithium on all the shifters I've rebuilt over the years and have no complaints. It seems to hold up for a very long time. There may be a better alternative,but I haven't heard of it yet.Thats whats so great about this site,you'll probable hear from a dozen people.
    Stephen Barrett (21558)
    • Larry M.
      • January 1, 1992
      • 2701
      I have always used white lithium grease (Lubriplate if available). Replenish every 3-4 years.
      Larry
      • Peter M.
        • April 8, 2007
        • 570
        They came from the factory with white lithium grease on the linkage which I have used on all of my Corvettes. It has always worked well for me.
        • Mike B.
          • July 31, 1994
          • 843
          Here's one more vote for white lithium grease. Definitely holds up well. I overhauled both M-21s and lubed all linkage pivots/levers/rod ends with an acid brush.
          Mike '65, '66
          • Jack M.
            • March 1, 1991
            • 1195
            Although white lithium grease is a excellent choice, I've sometimes opted for 'LPS 3' too.
