Drive Shaft U-bolt or Cap? - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 954
    Hi all,
    Did the drive shaft for 68 BB use u-bolts to connect to the differential / trans? I know the half shafts use the caps on BB, but not clear if the same was done for the drive shaft as well.
    If u-bolts, were they natural in finish or plated?
    Pat
    68 427 / 400
    88
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Drive Shaft U-bolt or Cap?
    Patrick U-bolts are correct I am going off of memory but that is what I recall even u-bolt on L88's drive shafts. Finish natural.
    Paul 18046
    • Kenneth T.
      • March 23, 2008
      • 631
      Pat, I hope this link works, if so it will answer your first question.
      It was posted by Joe L awhile back.
      https://www.forums.ncrs.org/showthre...nge#post483442
      Ken
        • 43248
        Ken
        Ken and Pat------
        ...and that would still be my answer to this question.
        • Patrick N.
          • March 10, 2008
          • 954
          Thank you everybody,
          I think this clears it up for me, drive shafts, BB or SB w Manual are connected with u-bolts, and correctly, my dif yokes are cast straps with hex head fasteners.
          U-bolts were on the drive shaft when I disassembled the car, but the differential had been replaced once prior - I could not be certain if it was put back together correctly.
          I am guessing that the u-bolts are natural finish?
          Thanks again!
          Pat
          68 427 / 400
          88
            • 43248
            Thanks again!
            Pat
            68 427 / 400
            88
            Patrick------
            No, they are black phosphate.
            • Patrick N.
              • March 10, 2008
              • 954
              great,
              Thanks again Joe!!
              Pat
