Early or late? - NCRS Discussion Boards
Early or late?
  • Pete G.
    • October 21, 2008
    • 50
    Early or late?
    Verifying intake manifold casting and date codes for my '68 427 L68. Unfortunately, the date code is on the underneath. Casting # (3937795)from documentation indicates it was used on late 427/400s. Is March 14 (vin 413723) considered "late"? What is cutoff point between early and late? According to documentation, my block casting # (3916321) is considered "early", block date code is L87 (Dec 7 '67).
    Thanks!
  • William C.
    • May 31, 1975
    • 6037
    Re: Early or late?
    Block casting date is not a marker for early/late for the assembled engine. A better reference would be the engine ID stamp indicating when the engine assembly was completed. Early and Late are generally an indication that a firm date is not known and are provided as a general guide, but the reference would still come from the engine assembly code on the front of the block.
    Bill Clupper #618
    • Pete G.
      • October 21, 2008
      • 50
      Re: Early or late?
      Thanks for reply Bill. Unfortunately, I did a poor job of explaining my delemma.
      I'm curious of intake cast # 3937795 matches to my car assemble date of Mar 14 '68? Restoration documentation I'm using indicates intake cast # 3937795 is for late '68 427/400s. Want to be sure that my car assembly date is not considered too early to have this intake installed on it.
      This would all be moot if I had not spaced out getting the date code off the bottom of the intake.....
      • Jack C.
        • September 30, 1992
        • 1090
        Re: Early or late?
        Pete, my January 22 built has intake 3919850. I've been told, mine is not early but closer to midrange which is VIN# 9643
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
