Brake and clutch pedal pads - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Anyone have a picture of the correct brake and clutch pedal pad for a '62? It seems that the part number 3884850 can be oval or square with different rib patterns etc.
    Thanks.
  • Richard P.
    • May 31, 2002
    • 190
    Re: Brake and clutch pedal pads
    They are not oval like the 56-57 but have rounded corners. Corvette Central has good repros.
    • John F.
      • March 23, 2008
      • 2419
      My 62 #0029 pads.
      • David H.
        • November 11, 2009
        • 777
        THis is what I was wondering about John.
        Your pads are what I would call oval.
        The pictured NOS pads are the same as what came off the car.
        Do you have the part number from the pads that you have pictured?
        My AIM says 3744748.
        • William C.
          • May 31, 1975
          • 6037
          Mine (used originals) look just like John's. Can't get into the barn to check part numbers now.
          Bill Clupper #618
          • Dick W.
            • 10483
            David, if I am not mistaken, your pads are C-3's
            Dick Whittington
            • John F.
              • March 23, 2008
              • 2419
              Just took one off very carefully #3744748-17 with a capital AY inside.
              • William C.
                • May 31, 1975
                • 6037
                Per 1963 Parts book, 3744748 Group 4.630 is what you need.
                Bill Clupper #618
                • David H.
                  • November 11, 2009
                  • 777
                  Looks like what was on the car where incorrect. Part number 3884850 apparently fits 1965-1969 Impala with manual transmission.
                  The 3744748 part number is correct as you say. I found it in the AIM also.
                  Oval instead of square.
                  Thanks all for your input.
