3894568 Ring and Pinion Gear - NCRS Discussion Boards
  • Jeff Z.
    • February 1, 1994
    • 94
    3894568 9:41 GM 11 66 2
    Jeff
    63 Convert 340 hp
    66 Coupe 300 hp
    67 Camaro 1500 hp
    00 SS Camaro 320 hp
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 3894568 Ring and Pinion Gear
    Originally posted by Jeff Zsoldos (23935)
    ...found what looks like a later dated 4:56 gear and posi unit. Can anyone verify the following part # is for 65 and up posi case. Haven’t had a chance to pull pinion gear to look at splines and crush sleeve length. Also date code doesn’t appear to be MDDYY.
    3894568 9:41 GM 11 66 2 ....
    Yes, that's the correct ring gear part # for '65-up to at least 1970. You might be able to look deep and see the pinion gear stamping as well; #3894566, and the month / date (the last digit is probably a shift or assembly station).
    Here's a 4.56 set I have: ring '568', 12_65_1; pinion '566', 11_65. Both 9-41 teeth ratio.
    • Gary F.
      • August 29, 2010
      • 248
      I have a 4:11 in my 63, and here is what's on the ring gear.
      1 - GM - 3733908 - 9 37 - 2 63
      The car was built March 18th.
