'62 trunk mat question - NCRS Discussion Boards
  • Charlie P.
    • July 31, 2003
    • 260
    The JG says that the trunk mat was a two-layer affair, rubber as the base with vinyl laminated to it. Does this hold true for black? I would think not, as the part number is said to be molded-in on the black, and stamped on the colored. This would indicate that the black mat was not two layers. The second layer of color would cover the molded-in part number, hence the ink stamp part number.
    The mat in the car I looked at had 6 22 3 stamped on the back. Sounds like maybe June 22, 3rd shift (?). Make sense? Car was built late July.
    Charlie
  • William C.
    • May 31, 1975
    • 6037
    Re: '62 trunk mat question
    Black is indeed one piece in '62.
    Bill Clupper #618
    • Mike E.
      • February 28, 1975
      • 5153
      Second layer was extremely thin--did not cover the molded-in part number on original colored mats, because original colored mats had no molded-in part number. 2nd generation GM mats had molded-in, thus no stamping necessary, and not correct for judging.
