No heat at the automatic choke - NCRS Discussion Boards
  • Calvin M.
    • August 31, 2000
    • 117
    #31
    Re: No heat at the automatic choke
    Here's some shots of the replacement and original manifold heat tube from my '57.
    The original is indented lengthwise on three sides, leaving a fairly small triangular cross section. The replacement only has one pressed in area, about a 1/2" long, as you can see in the pic. (The clevis pin to the left was my 'installation tool')
    • Stuart F.
      • August 31, 1996
      • 4676
      #32
      Calvin;
      What you show is more like what I remember the heat tube looking like. Thanks. Guess I wasn't going crazy after all. Now then, one can only speculate as to when and/or why/or if the design was changed, and if so, could this be the source of choke problems others are having with at least the C-2's?
      Stu Fox
      • Calvin M.
        • August 31, 2000
        • 117
        #33
        I think you're right, Stu.
        I scrounged around and found the heat tube pictured before, but got a better cross section shot vs. the end of the tube which is more representative of the entire length of the replacements (except for the 1/2" pressed in portion).
        The original tube appears far more restrictive.
        Cal
        • Stuart F.
          • August 31, 1996
          • 4676
          #34
          Cal;
          Great pictures.
          Thanks.
          Stu Fox
          • Timothy B.
            • April 30, 1983
            • 5186
            #35
            Hi Cal,
            Thanks for the pictures of the tube showing the restriction to air flow. My memory tells me the tube I removed from the 902 manifold on my 63 had no such restriction. The new tube that's installed looks exactly like your replacement part.
            This is interesting to me because if I block the air flow in this hot air circuit my engine rpm slows approx 100 +-. I described my problem above in a post and that's got me stumped, this condition could contribute to the issue I am working on.
