I've searched the archives but have not come up with the info I need. I remember a while back discussions reguarding available ignition points to use. Not sure, but I don't believe the Delco is availablle for the SHP engine (and can't find the part number for those anyway). so, looking at Accel now. Is the correct set for this application Accel # 8104 (points and condenser)?? this has the 32oz spring. Any other recommendations? Lastly, is it recommended to adjust these points in the middle of the dwell range, 30 degrees?
Thanks, Blake
Thanks, Blake
JD
I am running an MSD rotor is everything I work on
