I was cleaning up my 3rd arm assembly and noticed some wear on one side of the ball (see picture). The ball measures 0.99 diameter on the unworn area and 0.96 diameter on the worn area.
Does it need to be replaced?
If yes, if you have done it, did you have to heat it before peaning or can I do it cold? I replaced the clutch cross shaft ball on the frame and pean it cold and it worked and seems solid.
Don
Don
