3rd Arm Ball replacement? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    I was cleaning up my 3rd arm assembly and noticed some wear on one side of the ball (see picture). The ball measures 0.99 diameter on the unworn area and 0.96 diameter on the worn area.
    Does it need to be replaced?
    If yes, if you have done it, did you have to heat it before peaning or can I do it cold? I replaced the clutch cross shaft ball on the frame and pean it cold and it worked and seems solid.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
