Greetings all, although I have been a NCRS member for a few years now, this is my first post on your fine Forum. Let me start with a question.
Can you give me a ballpark figure of the value of a 1963 Corvette RE 340hp engine, long block with the correct heads and intake (but incorrect carb, distributor, exhaust manifolds, oil pan and balancer, let's call it a long block) and a 1963 Corvette RF 360hp FI short block (it has a set of later model heads and aftermarket intake, no distributor or carb) ?
Here's my short story :
While shopping for a buildable 327 engine so that I could pickle my numbers matching '66 engine I came across a fairly complete 1963 RE 340hp long block with the correct intake and a 1963 RF 360hp FI short block (it has later model heads and an aftermarket intake). Both of these engines have nice stamp pads, the codes and dates are easily legible as are the VINs on both blocks. Neither of these two VIN's appear on the C2Registry and it would be a blast to get the block back to the right car. I also like the idea on an "incorrect and stock appearing" 340hp mill in my '66. But then we are dealing with the cost to purchase and my limited garage space.
Here are the numbers:
3107156 F0102 RE (L172 Build Date)
3105819 F1121 RF (K162 Build Date)
Anyone out there have a '63 with these VIN's ?
I have photos that I would gladly send, you can reach me at rayvaflav@hotmail.com
I hope that I have the engine that you have been looking for.
Thanks in advance, Ray
