59 Tie Rod Ends - NCRS Discussion Boards
59 Tie Rod Ends
  • John F.
    • January 1, 2000
    • 155
    59 Tie Rod Ends
    Does anyone anyone know if there is someone reproducing a correct tie rod end for the C1s?
  • John F.
    • March 23, 2008
    • 2408
    Re: 59 Tie Rod Ends
    I ordered the whole rebuild kit from Paragon. Not sure where they were made, but work just fine.
    • Donald H.
      • November 2, 2009
      • 2580
      Re: 59 Tie Rod Ends
      Paragon has the ends that have grease fitting on the side instead of the bottom.
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • 43221
        Re: 59 Tie Rod Ends
        John------
        If you are referring to CONFIGURATION-CORRECT tie rod ends for C1's, I know of none on the market. However, when I USED TO peruse eBay on a regular basis I noticed that NOS C1 tie rod ends were often listed. I don't know if they still are.
