61-62 Headlight Bezel to Fender Top Trim Extensions - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    I see that the 1962 Headlight Bezel to Fender Top Trim Extensions are riveted onto the headlight bezel/door. In the AIM section 11-13 sheet 4 it shows the 2 rivets, but it is unclear if the rivet is part of the extension?
    If I drill out the rivet to remove the extension for painting, can I easily rivet it back on?
    Tony
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: 61-62 Headlight Bezel to Fender Top Trim Extensions
    There is no rivit used.
    The back of the extension has a cast in stud which goes through the painted headlight ring or bezel.
    It is sometimes difficult to get a good fit to the fender top trim.
    • Anthony P.
      • June 27, 2010
      • 485
      Should I just leave the extension in place and mask off around it for painting?
      The extension is nice and I do not plan on replacing it)
      Tony
      • Bruce B.
        • May 31, 1996
        • 2930
        You can either mask it for paint or grind off the flat part of the post and then epoxy it back on.
