1965 Sting Ray Coupe -Horn issue - NCRS Discussion Boards
  • Dean S.
    • December 15, 2010
    • 68
    My horn is going off whenever I turn the steering in certain directions and sometimes annoyingly won't shut off. Anyone know what could prevent ths from occurring again?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1965 Sting Ray Coupe -Horn issue
    For starters and to continue driving your 65 disconnect power to the horn relay or unplug your horns.
    • Philip C.
      • December 1, 1984
      • 1117
      Dean, Jim made a point, MAKE sure you disconnect power to the horn relay, you do not want power going to the relay untill you find your prolbem. DO NOT ONLY unplug the horns! The prolbem is most likely in the column. Phil 8063
        • 6955
        Dean look at the horn button to make sure there is not a problem in that area. If okay, You may have to dig into the column, you may have the grounded wire for the horn contact or a broken wire grounding out inside the column.
        A quick check under the column is move the harness around and see if the horn goes on and off while you move the wires around.
