63 corvette brg. retainer part no.-Joe L. - NCRS Discussion Boards
    • 6958
    Hi Joe, there is a 63 corvette front brg. retainer for sale on flea bay, part no. 3859032 is the the correct fo my 63 b/w T-10?
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 63 corvette brg. retainer part no.-Joe L.
    The 3859032 is a front bearing retainer for a 66 passenger car Saginaw 3 and 4 speed and 66 Corvette with three speed. It has a 4 3/4" diameter.
    63 (only) Corvette used a 604932 retainer. It has a 4 3/16" diameter.
    • Joe R.
      • July 31, 1976
      • 4552
      Well I ain't no Joe L. or M. Hanson but my T-10 just happens to be on the bench and it's bearing retainer number is 3790278.
      Maybe it's the wrong one!!!!!
      JR
      PS. That's probably the casting number. Should be one different for the PN.
      • Michael H.
        • January 29, 2008
        • 7477
        JR
        Joe,
        There were two different front bearing retainers used for 63. One was cast iron and the other was aluminum. I think the aluminum retainer was discontinued at some point during the 63 model run and replaced by the iron unit. The 604932 iron retainer was available for a few decades after 63 so it's probably the only NOS retainer that will ever be on ebay.
        I don't remember the casting number for either retainer.
          • 43286
          Edward-----
          Retainer GM #3859032 is not applicable to 63 Corvettes. It is applicable to 66-70 Corvettes with 3 speed as well as other applications.
          • Joe R.
            • July 31, 1976
            • 4552
            Michael,
            Never seen a 63 Muncie or T-10 with a cast iron retainer. They use the 3 speed front bearing and have to use the small bolt pattern with that small hole bellhousing.
            Have used a cast iron retainer on the 63's before but had to use a 64 or newer bellhousing.
            JR
            • Joe R.
              • July 31, 1976
              • 4552
              Edward-----
              Welcome to the program Joe!
              JR
                The original aluminum '63-only T-10 front bearing retainer was casting #3790278, later replaced by the iron #604932 due to galling problems with the aluminum part.
                  • 6958
                  Originally posted by Michael Hanson (4067)
                  Joe,
                  Mike, Has this no.(604932) been around for many years, I googled the part no. and it seems that there is a Vintage Auto Parts INC. listing it as a GM 1940 - 54
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Yup, and that change probably occured somewhere around mid 63 production.
                    It first apeared in the parts book as a change in August 1963, several months after the change in production.
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      Yes, it was first used in 1940-54 pass cars, 1941-47 comm/truck, and 63 pass/Corvette.
                        • 6958
                        Guys, thanks for all the replys and your help.
                        • Joe R.
                          • July 31, 1976
                          • 4552
                          That's strange that they never used the cast iron bearing retainer on the 63 Muncie. It also had the 3790278 bearing retainer. The first 63 Muncie I had was in the 14,000 mid range.
                          I always thought that retainer was used because of the bellhousing's smaller hole also used in all 63 GM 4 speed applications.
                          JR
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            JR
                            Yes, that's correct. All 63 Corvettes used the 421 bell housing with the small hole and all 63 3 and 4 speed transmissions used the small 4 3/16" bearing retainer. It was the only year that Corvette/pass used the small retainer. The later 63 release 604932 iron retainer was small diameter, just like the aluminum 3790278.
                            For 64 and later, the larger 4 3/4" 62 and earlier style bearing and retainer were used.
