Hoew many 1964 Coupes was made with shp engine, AC and PS? - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Any knows how many 64 Corvettes coupe was made with PB,AC and a shp engine?
    Its also tinted windows and such small extras on my car.
  • Bob H.
    • July 31, 2000
    • 809
    Re: Hoew many 1964 Coupes was made with shp engine, AC and PS?
    Hi Claus:
    I have owned 2 of them. One was blue/blue and the other saddle/saddle.
    They are very rare just 200+ I believe. I don't recall the exact #. That is the 365HP with air. Fuelies did not have the option of air. The engine code should end in "RR"
    Power brakes were great to help slow down the beast. I doubt there are numbers with the combo of air, p/b and 365.
    Also, 365/air cars did not have power steering as I recall. They had an adjustable pulley where the pump would go. Also, the power steering cylinder would not clear the oil pan.
    If you change the pan, then you could add p/s.
    Bob
    • Claus S.
      • December 30, 2010
      • 414
      Thanks. There is no power steering on my car and after what i can see there have never been.
      I have played with the idea of adding power steering
      • Wayne M.
        • March 1, 1980
        • 6414
        Well the total for '64 coupes with AC and L76 is 243 (Noland Vol 2, pg 213).
        Then, same source, pg 221; '64 [both body styles] w/ J50 and C60 and manual trans (3 sp, or 4 sp) = 226.
        So you'll have to do some iteration to estimate the number for your original combo.
        P.S. My bad -- obviously no N40 possible with big oil pan, per above responses.
        • Bob H.
          • July 31, 2000
          • 809
          Another unusual item on the air/365 car is the air conditioning compressor pulley. It is larger that other air cars to help compensate for the higher revs.
          My saddle car did have power steering added to it.
          Bob
          • Mike M.
            • May 31, 1974
            • 8383
            i've had my old 64 365/c-60 with K/O, no PB or PS. its a silver /black leather coupe. came outa calif in 1970 when i bought it. the Compressor pulley is larger than non-solid lifter cars and extremely rare. mike
            • Bruce S.
              • January 1, 2006
              • 26
              Mike
              You must have a twin to my original '64 coupe silver/black 365/ac/4-speed... but my car has an added plus with rare TI system.
              Bruce
              • Wayne M.
                • March 1, 1980
                • 6414
                ..... the Compressor pulley is larger than non-solid lifter cars and extremely rare. mike
                Here's a shot of a '64 compressor with the 6_1/4" dia. pulley; backplate date E_3_4.
                • Bruce S.
                  • January 1, 2006
                  • 26
                  Mike & Wayne
                  Here is a pic of my '64 365/AC compressor with the large pulley.
                  Bruce
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Hello Wayne;
                    Would this A/C pulley diameter also be used on '65 365HP ?
                    Thanks.
                    Ray
                    I hope you dance
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Originally posted by Ray Geiger (9992)
                      ...Would this A/C pulley diameter also be used on '65 365HP ? ....
                      Ray -- by all means; here's a nice '65 convertible from Calif. at NW regional in Seaside OR in 2006 (IIRC). The square holes in the front clutch hub may be wrong (personal opinion). This pulley is 6_3/8" diameter (per '65 TIM&JG).
                      • Ray G.
                        • May 31, 1986
                        • 1189
                        Hello Wayne;
                        Thanks for the picture and Info.
                        Your picture shows no paint in the center of the clutch assembly.
                        Maybe an indication of R&R.
                        Ray
                        I hope you dance
                        • Claus S.
                          • December 30, 2010
                          • 414
                          What a beatyful car you have
                          Originally posted by Bruce Smith (45002)
                          Mike & Wayne
                          Bruce
                          • Bruce S.
                            • January 1, 2006
                            • 26
                            Claus... Thanks for the complement, it's a very nice car.
                            Bruce
