67 BB Valve Cover Bolt ID Help - NCRS Discussion Boards
  • Dereck S.
    • July 30, 2008
    • 244
    Looking for help identifying an early 67 BB valve cover bolt headmarking. Attached are two pictures of valve cover bolts. One is a repro with "TR" headmark purchased from a Corvette parts supplier. The other bolt is identified with "TH" and three lines indicating grade. The "TH" bolt is also about 1/16" longer than the repro. I've not seen this headmark before. Could this represent a correct bolt for the application from a different GM bolt supplier?
    thanks,
    Dereck
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 67 BB Valve Cover Bolt ID Help
    Dereck,
    the TH is an aftermarket supplier/hardware store brand bolt not used on 67's. The grade 5 bolts for 67 valve covers would have one of several headmarkings some of which are, TR, SBC, RSC, RBW, L5 I know I'm forgetting a few here...remember the longer grade 5 bolts were only used in 4 locations which was under the ground strap loops for the plug wires. If you had radio delete then all 14 bolts would be grade 2 and the shorter style.
    Hope this helps, Rich
    • Dereck S.
      • July 30, 2008
      • 244
      Thanks Rich,
      I figured that was the case.
      Dereck
      • Rich P.
        • January 12, 2009
        • 1361
        Your welcome! I'll post pictures later tonight or tomorrow of original Valve cover bolts (both the grade 2 short stryle and grade 5 longe style)
        Rich
        • Rich P.
          • January 12, 2009
          • 1361
          Here are a few of the longer grade 5 bolts (I did not clean the heads and some are tough to see) They are SBC, SB, A, TR, NAT, RBW, L5 and P. I have others but this gives you an idea of what some are.
          Rich
          • Rich P.
            • January 12, 2009
            • 1361
            Duh forgot the picture
            • Dereck S.
              • July 30, 2008
              • 244
              Rich,
              Thanks for the pics. I was hoping I had some originals in a box of fasteners I had from back in the 80's. No luck. I'll have to hunt down some. The pics are a big help.
              thanks,
              Dereck
