C2 Parking Light?? What is this???? - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5346
    I came across this set of directional/parking lights for a C2. Take a look at the picture. There is no ground wire and there are only two male contacts in the rubber connector.
    The chrome and all the wires are in excellent condition.
  • John D.
    • December 1, 1979
    • 5507
    Re: C2 Parking Light?? What is this????
    Harry, Do you have a photo of the front side of the lamp/light. Thanx, JD
    • Harry S.
      • July 31, 2002
      • 5346
      John, yes I do, but it looks like every other C2 light you have seen.
      • William C.
        • May 31, 1975
        • 6037
        Looks like a home-made wiring repair.
        Bill Clupper #618
        • Harry S.
          • July 31, 2002
          • 5346
          Bill, I can see no repairs, everything looks perfect.
          What other GM vehicle used these?
          • William C.
            • May 31, 1975
            • 6037
            All I can tell you is that the earliest wiring print I have for '63 Corvette, released in Jan of '62, used the same three-wire hookup that is typically seen in all the '63 - 67 models. As the housing is angled to fit the Corvette body, chances of a same part-different application is slight. What is the casting number on the back of the pot metal part? I can't quite make it out, and I'd like to check it against the later models.
            Bill Clupper #618
            • Michael H.
              • January 29, 2008
              • 7477
              I know exactly what it is. It's a secret though.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11365
                You don't need the ground wire on a metal Corvette right? So it must be a spare for the 1972 XP-895 Aluminum bodied experimental Corvette at the Corvette Museum.
                Rich
                p.s. You coming to Kissimmee for the Regional? Bring some snow my wife misses it!
                • Paul D.
                  • January 1, 1988
                  • 101
                  It could be the turn signal for a mid 60's Flat face Chevy van.........P....
                  • Harry S.
                    • July 31, 2002
                    • 5346
                    From the back of the light:
                    5950980 an inch away is the number 1
                    GUIDE F2-60
                    MADE IN U.S.A.
                    I think they are 1960 Chevrolet parking lights.
                    • William C.
                      • May 31, 1975
                      • 6037
                      Anyone have a '60-65 chevy truck to look at for reference? Possibly '61-65 Step van or ??
                      Bill Clupper #618
                      • Harry S.
                        • July 31, 2002
                        • 5346
                        I found this:
                        • Doug F.
                          • November 1, 1983
                          • 322
                          1960 Pontiac
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Ok, Ok, I know you guys will figure it out eventually. Here's the deal.
                            The first clue is the lens. I'm sure most of you have seen the two different part numbers on the lens. One is 5954440, amber, and the other is 5950387, crystal. Crystal means clear, or not amber shaded.
                            Since 62 or 63 (?) was the first year that amber lenses were fed required, that means the crystal lens had to be used for vehicles prior to that time.
                            The part number comes from the Pontiac division of GM and the lens was used on all 1960 Pontiacs.
                            Has anyone ever noticed that the 1960 Pontiac parking lamp assy looks similar to the ones used for 63-67 Corvette? In fact, other than a few minor details, it's exactly the same.
                            Yes folks, the 63-67 Corvette parking lamp assy's were indeed borrowed from Pontiac division.
                            The difference in the wiring was described by someone above. No need for the third/ground wire on a steel body.
                            This should also answer another question. Why in the world would engineering design a parking lamp housing for a Corvette that places the assembly directly in front of a wheel/tire, and have lens screws that poke all the way through the housing, into salt water spray etc? Well, because they didn't. It was a desigh for a vehicle that placed the lamps well away from salt spray, inside the grille of the Pontiac.
                            And finally, we've all seen the weird Corvette lamp assy's from some 64 and 65 Corvettes that have a separate ground wire, soldered to the side of the socket assembly, right?
                            Yup, lamp assy's that were borrowed from the Pontiac side that could be modified to be used and Corvette.
                            There... the secret's out.
                            • Bob J.
                              • December 1, 1977
                              • 720
                              Hanson figured this out 30 years ago !
