Correct clutch fan for '62 - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Can anyone tell me if this clutch fan that was on my brother's car is correct for the 340hp engine?
    And,
    if it is, how should it be painted on the front of the clutch?
    thanks
  • Mike M.
    • May 31, 1974
    • 8382
    Re: Correct clutch fan for '62
    can you post a photo of a close-up of the shaft?mike
    • Grant W.
      • December 1, 1987
      • 407
      And,
      thanks
      Looks right for your 62. The early ones had a little nib off to the right of the Spring.
      No black paint on the fan clutch at all. Also on the front of the fan clutch on the 12, 3, 6, and 9 oclock position you see the flat spot with a hole in it. That is a correct corvette item.
      Hope this helps.
      Grant
      • David H.
        • November 11, 2009
        • 777
        Thank you Grant, I thought it was correct. I will remove the black paint.
        Mike, I have attached another picture of the shaft. Is this what you wanted to see?
        • Mike M.
          • May 31, 1974
          • 8382
          that's a 62 shaft and the rest of the pics support that the fan clutch is appropriate for a 62 vette.mike
          • Rick C.
            • March 1, 1986
            • 183
            Mike,
            What is it about the shaft that makes it a '62?
            Rick
            • Mike M.
              • May 31, 1974
              • 8382
              Originally posted by Rick Casper (9781)
              Mike,
              Rick
              the fact that the outside diameter is uniform(no step in it) excludes it as a service replacement. the service replacements are much more common on the c-2 judging fields. mike
              • David H.
                • November 11, 2009
                • 777
                Thanks for your help on this one everyone!
                • Robert B.
                  • December 1, 1999
                  • 56
                  Dave,
                  Here are links to a couple of pictures of the clutch fan for my '60 270 horse that I got back from Fred Oliva today. Glad to see you are progressing!
                  1960 Corvette Fan Clutch Restored by Fred Oliva
                  • David H.
                    • November 11, 2009
                    • 777
                    Thanks Bob, the pictures will help me.
                    Two steps forward......One step back......Two steps forward......One step back!
                    But forward progress indeed.
