I need advise on how to remove the radio from the console after the right side dash pad, forward console plates, wiper switch trim plate, passenger side radio bracket, and center cluster screws have been removed. I have wing nuts on the center cluster bottom studs and they have been loosened. The center gauge cluster is loose but I have not attempted to pull it out of the bottom bracket slots since the radio sits behind it. Obviously the radio knobs and nuts have also been remove.
The question is do I remove the radio by pushing the gauge cluster/radio assembly forward from the bottom until the studs come out of the bracket slots or do I try to remove the radio first without having pulled the cluster studs out of the bracket slots. Is there enough room behind the radio to move the assembly so that the cluster studs clear the slots? The heater floor outlet sits right behind the radio and there very little room to pull the radio towards the front of the car. The 1971 Chasis Service Manual says to remove the floor heater duct behind the radio before removing the radio but I can't figure out how to remove this duct either. The 1972 Chasis Service manual does mention anything about removing the floor heater duct.
