Tires for 1967 Coupe - NCRS Discussion Boards
  • Stephen M.
    • February 5, 2010
    • 1
    I have a set of Firestone redline 75.15 bias ply tires mounted to a set of bolt-ons and just acquired a set of rally wheels to mount a set of radial tires for better handling. Can anyone tell me what the correct tire would be to replace the bias ply with the radial and where is the best place to purchase these tires? Thanks for your help
    Steve
    New member #51365
  • Michael H.
    • December 1, 1987
    • 728
    Re: Tires for 1967 Coupe
    Steve,
    I think you need to move this from the dealer section to the technical section. I would look at the 205-75-15 Michelin X redlines at Diamond Back tires, not cheap but a great tire. Are you going to be selling the redline bias tires, I'm looking for a set ?
    Mike
    • Arland D.
      Moderator
      • July 31, 1980
      • 421
      Steve,
      Mike was correct about your post being better served in the technical discussion board. I will move your post accordingly. Regards,
      Arland
      • Michael J.
        • January 27, 2009
        • 7122
        Originally posted by Michael Hanley (12271)
        Steve,
        Mike
        Mike is also correct about the Michelin X radial redlines at Diamond Back. I have put a set on my '67 coupe, mounted on American Torq-Thrust Ds, and they handle so much better than those bias ply things it is like night and day. Save the bias ply for judging, they are best stacked in the garage most of the time.
        • Joe R.
          • May 31, 2006
          • 1822
          Steve,
          Here's a thread about some more tires to consider:
          https://www.forums.ncrs.org/showthre...547#post528022
          Joe
          • Ron N.
            • August 18, 2008
            • 243
            Steve, I'm using 215 70 15 Michelin Semmetry (all season) from Discount Tires. Reasonable price, has been a good tire on my 67 for 2+ years. They come in B/W and white stripe. Four other guys in mt group have the same tires and have not heard of an problems.
            Ron
            • Kenneth B.
              • August 31, 1984
              • 2089
              Ron
              I had 215's on my big block 67 & when I turned sharp into a driveway with a slight curb bump it hit the lip of the left front fender. I see no reason to put bigger tires on than 205's. Better safe than sorry. I have had no problem since. What reason would you need to put bigger ones on. My car set up with no front spring sag.
              KEN
