1966 thermostat housing - NCRS Discussion Boards
  • Jack M.
    Infrequent User
    • January 1, 2006
    • 12
    can someone tell me what is the correct thermostat housing, for a 1966 300hp, 327, with powerglide build date 6/1966
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 1966 thermostat housing
    Aluminum casting part number 3877660 with a tab for a throttle return spring although this tab isn't used. RS
    • Mike E.
      • February 28, 1975
      • 5138
      Methinks you asked the question on the wrong discussion board, but looks like you got a correct answer.
      • Jack M.
        Infrequent User
        • January 1, 2006
        • 12
        1 am new at this where do i need to post my question
        • Jack M.
          Infrequent User
          • January 1, 2006
          • 12
          what discussion board do i need ask
          • Arland D.
            Moderator
            • July 31, 1980
            • 421
            Jack,
            Your post is in the dealer information search - I will move it to the technical discussion board. Regards,
            Arland
