66 Holly Carb dating - NCRS Discussion Boards
  • John F.
    • July 31, 1999
    • 105
    I'm looking at buying a Holley carb for my 66 327/300. It is a List 3367 with a date code of 3465. I understand this uses a Julian calendar dating scheme. The JG does not seem to allow for use of the Julian calendar, but Allen Colvins "Corvette by the Numbers" explains that both the 3 digit system described in the JG and the Julian system were used until 1972 when only the Julian calendar was applied. Would a carb with the 4 digit date be considered correct for judging purposes or is this a service replacement?
    John
    • 15621
    Re: 66 Holly Carb dating
    I can't tell you about mid-years -- but I can tell you that for 1968-1972 (the only factory Holley equipped C3 Corvettes) the Julian dating system WILL receive a date deduction -- in spite of what Alan Colvin says. I would expect the same for mid-years, but I don't know that for a fact. There are lots of people here who do know though, so hang on.
    • Larry M.
      • January 1, 1992
      • 2701
      I would expect to see a three digit date code on an original 1966 Holley carb (YEAR/MONTH/WEEK OF MONTH).
      One with a four digit code would be judged as a service replacement. Deduction(s) would be for the date and any other minor changes/deviations from known original (ie. fuel bowl screw heads, fuel bowl configuration, other stampings and codes, etc, etc)
      Larry
      • William C.
        • May 31, 1975
        • 6037
        Not the first error in Colvin's book...
        Bill Clupper #618
        • John F.
          • July 31, 1999
          • 105
          Thats what I figured. Thanks guys.
          John
            Originally posted by John Farren (32715)
            Allen Colvins "Corvette by the Numbers" explains that both the 3 digit system described in the JG and the Julian system were used until 1972 when only the Julian calendar was applied. John
            John -
            If you'll re-read that sentence on page 183, it says "Holley used both these systems of dating but only used the four-digit code after the 1972 model year". The two dating charts on page 184 are separated, with the 1963-1972 chart showing three digits, and the 1972-1975 chart showing four digits.
            • John F.
              • July 31, 1999
              • 105
              I obviously misinterpreted this. Thanks for pointing it out.
              John
              • Philip C.
                • December 1, 1984
                • 1117
                Not for nothing Bill but I think his books have a better average than we do. Phil 8063
