The float is sticking on the secondary bowl and I have removed the 4 screws holding the bowl to the body but cannot remove the bowl. Is there something else that should be removed or has the gasket caused these parts to adhere.
I usually don't have a problem taking thinks apart, it's putting them back together that is sometimes difficult.
Thank you in advance for your answer.
