64 Differential Fill Plug Gasket - NCRS Discussion Boards
  • Neil L.
    • January 31, 1997
    • 44
    What type of gasket is used on a 64 differential fill plug. My parts book calls for a gasket, 3714775, which is discontinued. Paragon says it should be a copper washer. The only thread I could find in the archives dealt with the plug for 65-79.
  • Dan H.
    • July 31, 1977
    • 1364
    Re: 64 Differential Fill Plug Gasket
    Hi Neil, no matter what gasket you use, it will probably leak a little, especially with posi warning disc in place. Recommend Loctite 545 thread sealant in addition to a gasket, only way I got my 64 to quit weeping.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Gary R.
      • March 31, 1989
      • 1796
      Some used an o-ring, look to see if there is an under cut on the plug. The 63-64 were a machine thread then they went to 3/4 npt plugs in 65.
        • January 31, 1988
        • 43191
        Neil------
        I have some NOS examples of the GM #3714775 gasket. It appears to me to be cut from about 1/8" thick brown leather.
        • Philip C.
          • November 30, 1984
          • 1117
          Hi Neil Long Island sells a cork gasket. If thats all you need I'll pick one up and mail it to you, Iam putting my 63 together so Iam down there alot. Phil 8063
          • John D.
            • November 30, 1979
            • 5507
            Dan, The Loctite 545 is a life safer. Probably one of the best Loctites made when it comes to fluids.
            Must be or Cat and Harley D wouldn't use it on the assembly line.
            Loctite 545 comes from industrial tool supply companies. Not auto stores.
            My 63 Oil pan plug alway oozed a tad. Smeared it with 545 and no more leak.
            Great for anything hydraulic.
