Valve Cover Question - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    Question regarding horsepower label on a '66 327/300 valve cover:
    Sticker or Decal?
    I've read the archives and found a post that stated (at least for a FI '65) correct would be water based decal. Were there decals some years and stickers for others?
    One of my stickers is peeling up and needs replacement and I would like to do it right.
    Thanks (sorry for the mundane question)
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
    Re: Valve Cover Question
    Sticker or Decal?
    Rob -
    The new '66 JG describes the item that goes in the top center area of the valve cover as a "label", which has an adhesive backing with a peel-off liner. The separate "300 Horsepower" item used on the side of the valve cover on very early engines is described as a "decal", which was water-soluble (like the ones used on optional engines with aluminum valve covers).
    To confuse things, the Assembly Manual shows the item for the top center of the valve cover as a "decal", but the illustration shows one corner turned up, which indicates that it has an adhesive backing.
    • Rob M.
      • April 30, 2003
      • 657
      John,
      Thanks for the response. It sounds like a sticker it is . . . any suggestions on supplier? LIC I assume sells them.
      Again, thanks
      Rob
      '08 6 speed coupe
        John,
        Again, thanks
        Rob -
        Paragon has them as their #8198K; I'm sure LICS has them too.
