C2 brake line to front frame clip - NCRS Discussion Boards
  • Erik H.
    • October 8, 2007
    • 45
    Hi and Happy New Year to all! I can't locate definitive info on which clip should be used to hold the brake line to the frame directly below the steering linkage on my late 63 car. I've attached a photo of the current clip, as well as my three choices. Someone mentioned to me that this clip should be the black one (which is simply a zinc cad clip painted black, not the green clip I have in place now). Which is correct?
  • Rich P.
    • January 12, 2009
    • 1361
    Re: C2 brake line to front frame clip
    Erick,
    the clip you have in place now is Typical Factory Production.
    That should start your new year off right.
    • Tom H.
      • December 1, 1993
      • 3440
      Erik
      The clip on my 63 coupe is like your existing clip.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Erik H.
        • October 8, 2007
        • 45
        Thanks Rich and Tom! By luck, Jeff's post from 12/30 also shows these clips perfectly - just shows the value of browsing the threads!
        https://www.forums.ncrs.org/showthre...83340&uid=2561
