1968 Survey - Need Owners to Check 2 items - NCRS Discussion Boards
  • Terry B.
    • August 31, 1999
    • 607
    '68 owners - please take a moment to respond to this thread to help with the new edition of the '68/'69 TJM. Please physically check before responding:
    1. Build Date of your '68 or its' vin #
    2. Does your '68 have a warning light at the top of the speedometer that comes on if the headlight switch is on but the doors are not open?
    3. Does your fan blower operate with the left thumb wheel in the OFF position?
    Thanks -
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
  • John C.
    • January 1, 2005
    • 616
    Re: 1968 Survey - Need Owners to Check 2 items
    1. April 18th
    2. No
    3. No
    John
    • Tom H.
      • December 1, 1993
      • 3440
      Hi Terry !!!
      Just a comment on your blower fan question. Does the answer need to include if the car has AC or not ???
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Terry B.
        • August 31, 1999
        • 607
        Tom,
        No, I do not believe it makes a difference if the car has AC or not. We are looking at fan operation in the off position of the wheel control. Let me know if AC cars would make a difference.
        Terry Buchanan
        Corvettes Owned:
        1977 Coupe
        • Dale C.
          • November 1, 1999
          • 844
          Trim March 8th 1968, C60, (No and No)
          Dale
          • Dave S.
            • August 31, 1992
            • 2930
            Dale
            Terry,
            Just a comment from a 70-72 guy.
            I found that the blower motor works in 70-72 cars but the damper is not open, thus there is no real air flow. May be the same in 68/69.
            • Rich G.
              • August 31, 2002
              • 1405
              Delete...will check to be sure
              Last edited by Rich G.; January 1, 2011, 04:17 PM. Reason: Misread question...need to check
              • Jim T.
                • March 1, 1993
                • 5351
                Terry this is my input for 68 original owner convertible without air conditioning.
                1. February 19, 1968
                2. No
                3. YES
                It does not matter if the left thumbwheel is in the OFF position or any other position, the fan blower lever when moved from its off position will blow on positions one, two, and three. The fan blower runs whenever the switch is not in the off position, all the way to the left.
                The owners manual for a 1968 Corvette having factory air conditioning is different than a 1970's owners manual. In the 70's manual if the fan motor selector is all the way to the left and the thumbwheel is moved to select MAX, NORMAL, or BI-LEVEL the fan motor will function. Other selections will not operate the fan motor until it moved from the off position. My 1970 original owner coupe with factory air operates this way.
                The 68's owners manual for factory air conditioning does not mention this feature.
                • John C.
                  • January 1, 2005
                  • 616
                  Originally posted by John Carlson (43123)
                  1. April 18th
                  2. No
                  3. No
                  John
                  After reading the others responses I'm going to change my answer on question 3. Yes, the fan will run if left thumb wheel is set to off.
                  In my response I was getting thumb wheel and fan switch confused. You should never answer technical questions on New Years Eve.
                  John
                  • Anthony S.
                    • April 3, 2008
                    • 183
                    1- #9736 Jan. 24
                    2- No
                    3- No when OFF, but it will turn on if just a hair below OFF
                    • Rich G.
                      • August 31, 2002
                      • 1405
                      July 18, 1968 build
                      No Light
                      Yes, blower will run even when the wheel control (NOT the blower control) is in the OFF position.
                      Non- AC car
                      Rich G
                      • Jack C.
                        • September 30, 1992
                        • 1090
                        January 22 Build Date #9643
                        No light
                        Yes, the fan will still operate with the wheel in the off position.
                        Jack Corso
                        1972 Elkhart Green LT-1 Coupe 43,200 miles
                        Top Flight 1994, 2018 & 2021
                        • John P.
                          • January 28, 2009
                          • 7
                          A) July 26, 1968
                          B) No
                          C) No
                          Best to the board this New Year!
                          John Pratt
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            Hey Terry !
                            I can participate in your survey after all !! We've got a 68 convertible in the shop today for some service.
                            Build date C02. VIN # 109X
                            No headlight indicator.
                            Non AC car. Fan blows with left thumb wheel off.
                            Tom Hendricks
