1970 Transmission - NCRS Discussion Boards
1970 Transmission
  • Curt S.
    • April 30, 1975
    • 64
    1970 Transmission
    I own 1970 #4142 that has an incorrect 4 speed . It was assembled around February 10 1970. Do I need a 660 gear case or 661 to begin my assembly of a correct trans? Thanks Curt
  • Patrick B.
    • August 31, 1985
    • 2012
    Re: 1970 Transmission
    All 1970 transmissions used the 661 case including the late 1969 Corvettes and Camaros built during the nominal 1970 model year.
    • Eric D.
      • February 1, 1992
      • 42
      Curt, You need a 661 main case for you Corvette...
      Patrick, 660 main cases were used as late as Oct. of the 1969 calender year(I have a P0R27B 660 case VIN 10L147159 in stock)...
      661 cases were used as early as Oct. 1969 calender year(I have a P9R10A 661 case VIN 29N119544 in stock)... I have seen Sept 1969 661 cases also...
      Hope this helps... Crash
      • Curt S.
        • April 30, 1975
        • 64
        Patrick and Eric. Thank you for your expertise. The 1970 production year was different so I wanted to be sure what I would be seeking. Thanks again Curt
        • Michael F.
          • 745
          remember 70 vettes came out in I believe feb of 70 and a lot of 70s have 69 parts on them (casting dates that is)
          Michael
          70 Mulsanne Blue LT-1
          03 Electron Blue Z06
            • 15632
            The first production 1970 Corvettes have A05 on the trim tag. January 5, 1970.
